Skip to Main Content
IBM Z Software
This portal is to open public enhancement requests against IBM Z Software products. To view all of your ideas submitted to IBM, create and manage groups of Ideas, or create an idea explicitly set to be either visible by all (public) or visible only to you and IBM (private), use the IBM Unified Ideas Portal (https://ideas.ibm.com).
Shape the future of IBM!
Search existing ideas
Post your ideas
  1. Post an idea.
Status Delivered
Created by Guest
Created on Aug 7, 2014
Enhance display of module loaded in batch
FA lacks the ability to show __all__ modules loaded into a batch address space. Currently FA focusses at the call chain and the modules registered by LE at the abending enclave. The mini dump does not contain the relevant control blocks to identify all modules loaded via STEPLIB/JOBLIB and LNKLST: CDE/LLE chain from RB.
During complicated problem analysis a display of all modules in the Job Pack Area together with their entry point address, link date and indication from which loadlib they were loaded.
Idea priority Medium
  • Guest
    Feb 19, 2016
    This functionality can be achieved by using a Formatting user exit to buzz the CDEs and calling EVALUATE for the desired length to ensure the relevant storage pages are included in the Fault Entry. I have written a basic user formatting exec to do this which I am happy to pass on to you for your evaluation/use.
    Adrian Simcock
  • Guest
    Nov 19, 2015
    Due to processing by IBM, this request was reassigned to have the following updated attributes:
    Brand - Servers and Systems Software
    Product family - Development Tooling
    Product - IBM Fault Analyzer
    For recording keeping, the previous attributes were:
    Brand - WebSphere
    Product family - Enterprise Tooling
